Herb In Texas Posted December 15, 2010 Posted December 15, 2010 With all the talk of building trailers it got my giddyup goin so a question for ya'll. I plan to build a trailer similar to the aluma, the construction of it is going to be pretty straigt forward. My question is about rubber torsion axels. When I calculate where the axle will go I know the 60/40 rule applys but do I center the wheel hub or the rubber flexi part on that line or split the difference? Retarded mind want to know,lol
Tom Posted December 15, 2010 Posted December 15, 2010 I will measure my Aluma and get back with you later today
Tom Posted December 15, 2010 Posted December 15, 2010 Herb,The TOTAL LENGTH of trailer measured from end of tongue is 86 inches,the box is 46.5 inches from very farthest point to back of trailer where box ends,the torsion AXLE sits at 63.5 inches from very front TONGUE of trailer,and it is 68 inches to the center hub on the trailer. So l;ooking at the trailer the AXLE part of the torsion setup is forwardof center of the box. Im by no means a builder of any sort so if you need specific measurements feel free to call me and I will measure whatever you need....OR If you happen to come down this way,pick up my trailer and take it back with you and copy the design..or I will meet you half way in my pickup.I dont need it till July. Tom
Herb In Texas Posted December 15, 2010 Author Posted December 15, 2010 (edited) Just need to know the box length then how far from the front of the box to the center of the axle and then to the center of the hub. I can figure it out from there. Thanks Edited December 15, 2010 by Herb In Texas added last line and thanks
Herb In Texas Posted December 15, 2010 Author Posted December 15, 2010 I have been chewing on this all day, I work with my hands so my scull is free to do as it pleases. Anyway, to my thinking the place where the axle mounts would be the fulcrum point and therefore should be at the 60/40 spot. But when you think about a leaf spring setup, the axle is at this point there by the hub center is there also. Hence the question is it correct to have the 60/40 point where the rubber meets the road or where the fulcrum would be. There by having the rubber meet the road several inces back. Now if the trailer were 16 feet long the effect would not be as dramatic, but since the box length is going to be about 5 ft or so, reduced length = more critical correctness. But thats just how my head works. But then again if the rubber meets the road is several inches back then that would translate into a greater load on the hitch thereby reducing the possibility of the fearsome tail wagging the dog syndrom. Chingow my head hurts. Think I'll ride home the long way. BTW thanks for the offer of picking up your trailer Tom. If we can't sort it out on the board then maybe the week after Christmas I will sneek down your way and have a look. Whats a couple a hundred miles on a wing any way, TIME WELL SPENT. Wouldn't nessesarily need to drag it home. Just look at it a while.
Tom Posted December 15, 2010 Posted December 15, 2010 Very bottom of box is 40 inches long....center of hub from front is 23 inches
Herb In Texas Posted December 16, 2010 Author Posted December 16, 2010 Thanks Tom I have gathered some material already. mainly the angle iron to build the base frame. I'll go to Northern Tool tomorrow to order the torsion axle. Should be starting in a week or ten days. Iffffffff My skill set can match my vision then it should come out pretty cool. Got a yard in Fort Worth that sells "useable" scrap, might can get a good deal on the aluminum for the box and lid. Good result or bad I'll post.
Herb In Texas Posted December 16, 2010 Author Posted December 16, 2010 All right then. Going to have to get Dawn involved for that part though. My pics are all the time to light or too dark or to big or too small or too what ever. can you tell I don't get along with HER camera very well?
kj5ix Posted December 25, 2010 Posted December 25, 2010 Herb, this may help a little. You can go a little longer on the tongue, but not shorter than the 1.5 http://nomad.eurekaboy.com/mctrailer51.jpg
