Can anyone give a quick tutorial on what the codes on spark plugs mean?
for my 83 VR (1200) The manual says I need DGK DPR8EA-9 or X24EPR-U9(Nippon Denso)
(is Nipon Denso the manufacturer???)
The plugs that are in the bike from the PO are NGK R DR8ES-L (which the largest CTC in Canada (Kingston, ON) doesn't stock!
so...what do you folks recommend?
NGK DPR8EA-9's Work great. Some Autolite's work good 1164's I think but not sure right now. The Autolites are only about $1.50 each wich makes them a good deal and can be replaced without going to the bank.
Thanks Dingy! More information than I know what to do with...but I figure I can't go wrong with following the manual! (can I????)
  shaynes said:
...for my 83 VR (1200) The manual says I need NGK DPR8EA-9 or
I looked in the owners manual for my 2007 RSV and it too uses the DPR8EA-9 from NGK.
SO I tak the sheet that dingy proviede and come up with this:
Thread Diamater
D: 12 mm
Construction
P: Projected Insulator Type
R: Resistor Type
Heat rating nubmer
8: 8 in a sacle from 2 (Hot) to 11 (Cold)
Fireing End Clonstruction
E: Electrode (14mm only) 1.5mm Insulator
A: Special Design
Wide Gap (Gap Width)
9: 0.9MM (0.032")
dingy,
Thanks for the chart.
  • 1 year later...
  dingy said:
Attached is PDF of NGK codes.
Gary
Great info Gary!! I've had the nomenclature explained to me before (heat range mostly) but this is fantastic. If you can't find the plugs you need. You can match up any brand and be sure of what you're getting.:clap2:
Edited by Yamamike
booboo
Hey Trader,
IMHO you can't be wrong by following the manual but don't forget...they were written 25+ years ago and spark plug technology has evolved (like everything else).:2cents:
