Trader Posted July 12, 2010 Posted July 12, 2010 Can anyone give a quick tutorial on what the codes on spark plugs mean? for my 83 VR (1200) The manual says I need DGK DPR8EA-9 or X24EPR-U9(Nippon Denso) (is Nipon Denso the manufacturer???) The plugs that are in the bike from the PO are NGK R DR8ES-L (which the largest CTC in Canada (Kingston, ON) doesn't stock! so...what do you folks recommend?
Yammer Dan Posted July 12, 2010 Posted July 12, 2010 NGK DPR8EA-9's Work great. Some Autolite's work good 1164's I think but not sure right now. The Autolites are only about $1.50 each wich makes them a good deal and can be replaced without going to the bank.
dingy Posted July 12, 2010 Posted July 12, 2010 (edited) Attached is PDF of NGK codes. Gary Edited July 12, 2010 by dingy added ngk
Trader Posted July 12, 2010 Author Posted July 12, 2010 Thanks Dingy! More information than I know what to do with...but I figure I can't go wrong with following the manual! (can I????)
KiteSquid Posted July 12, 2010 Posted July 12, 2010 ...for my 83 VR (1200) The manual says I need NGK DPR8EA-9 or I looked in the owners manual for my 2007 RSV and it too uses the DPR8EA-9 from NGK. SO I tak the sheet that dingy proviede and come up with this: Thread Diamater D: 12 mm Construction P: Projected Insulator Type R: Resistor Type Heat rating nubmer 8: 8 in a sacle from 2 (Hot) to 11 (Cold) Fireing End Clonstruction E: Electrode (14mm only) 1.5mm Insulator A: Special Design Wide Gap (Gap Width) 9: 0.9MM (0.032") dingy, Thanks for the chart.
Yamamike Posted November 7, 2011 Posted November 7, 2011 (edited) Attached is PDF of NGK codes. Gary Great info Gary!! I've had the nomenclature explained to me before (heat range mostly) but this is fantastic. If you can't find the plugs you need. You can match up any brand and be sure of what you're getting. Edited November 7, 2011 by Yamamike booboo
Yamamike Posted November 7, 2011 Posted November 7, 2011 Thanks Dingy! More information than I know what to do with...but I figure I can't go wrong with following the manual! (can I????) Hey Trader, IMHO you can't be wrong by following the manual but don't forget...they were written 25+ years ago and spark plug technology has evolved (like everything else).
