Dave77459 Posted July 1, 2010 Share #1 Posted July 1, 2010 I need to remove the front rotors to work the HF bead breaker I have (without breaking the rotors). What the heck are those screws holding the covers on? Torx maybe? Dave Link to comment Share on other sites More sharing options...
Freebird Posted July 1, 2010 Share #2 Posted July 1, 2010 Yes, they are Torx. My '99 has allen head screws but I some point, they went to the Torx screws. I ran into them when removing some rotors at maintenance day. Link to comment Share on other sites More sharing options...
V7Goose Posted July 1, 2010 Share #3 Posted July 1, 2010 Needs a Trox T40 bit. Be sure to locktite them when you put them back together (called for in the shop manual). You will need to have the bottom rotor off to fit the wheel holder, and I strongly recommend you remove the other one to just be extra safe while mounting the tire. Very easy, especially with a power wrench, and a WHOLE lot cheaper than a new rotor! Goose Link to comment Share on other sites More sharing options...
Dave77459 Posted July 1, 2010 Author Share #4 Posted July 1, 2010 Thank you for the replies. Yes, they are Torx. My '99 has allen head screws but I some point, they went to the Torx screws. I ran into them when removing some rotors at maintenance day. Yup, Torx. Why oh why did they add a new tool? Needs a Trox T40 bit. Be sure to locktite them when you put them back together (called for in the shop manual). You will need to have the bottom rotor off to fit the wheel holder, and I strongly recommend you remove the other one to just be extra safe while mounting the tire. Very easy, especially with a power wrench, and a WHOLE lot cheaper than a new rotor! Goose I took off both rotors. I don't know why I have a T40, but I do. I got this thing (below). It'll be OK for the occasional tire changing. Next time, I'll time it better so that I can make it to a maintenance day before I change my tires! http://www.harborfreight.com/media/catalog/product/cache/1/thumbnail/370x370/9df78eab33525d08d6e5fb8d27136e95/i/m/image_4201.jpg Dave Link to comment Share on other sites More sharing options...
