jasonm. Posted June 28, 2010 Posted June 28, 2010 I did post this on the other thread. But wanted to give all a heads up... Well, here I am. Finally able to breathe. Been working on these carbs for weeks. Got a spare set off Ebay. They were in good shape. I used the #3 & 4 bank w/new parts needed. Now my power is linear. Did 125 mile back road ONLY ride. Speeds of 45-70. My overall average was close to 55mph. So, I was using a lot of the pilot jet. Went and filled up at the end of the ride. I really tried to get in as much as I could in the tank by shaking the bike on the center stand...could only fit 2.9 gallons in. That's 43mpg in the hilly area I live in. Pretty damn good and close to what I always got for the past 20 years with this beast. NOW-Neither #3 nor 4 plugs are black. #3 is light brown spot on the tip and #4 is almost white, like 1 & 2. I have #3 pilot screw is 2 ccw turns out and #4 is 2.25 or so-ccw. Note: all settings using digital tach. Prior to this latest carb work. I could not break 40mpg. Last remove / rebuild times, the float/fluid height was dead on and did not change. But still had it too rich somehow. NOW-Something just works better with these Ebay carbs. I know there is something I must have done wrong since the original carb rebuild a year ago. And #1 and 2 have never had an issue. As far as #3&4 problems, I am not entirely sure what the cause was or is on the originals. So my original set of 3 & 4 will just sit. I will be getting it EGA'd soon, to get this finished. I don't think #3 should be the only "brown" plug. But it's better than the black I had before. And the fuel mileage speaks for itself. Thanks for all the suggestions. Even if I haven't a clear idea why she was rich and what I did to fix it. Now if it skips/misfires at idle when hot. My profession being in electronics. I am not worried if it's an electrical issue, coils, or TCI. Because that's all that's left. Hope this is the last of this issue. I bet you hope the same... You must be tried of me by now.
Yammer Dan Posted June 28, 2010 Posted June 28, 2010 Glad you are getting there. I'm finally making progress on mine. Quit trying to listen to everything and went back to what I know!!! Ran like a dream today.
