Hazenson Posted May 21, 2010 Posted May 21, 2010 Im adding another light to the trailer and as I was hooking it up my running lights on the trailer went out. All lights work on the bike and trailer- except trailer running lights. Just figured I blew a fuse but when checked they all are good. So I got my tester out and there is no power coming out of pigtail for the running lights. I have the trailer light assembly (wiring box) with the extra fuse box. I checked all fuses except main- i know its not that one cuz everything else works. Is it possible I fried something in that trailer wiring block? Anyone have any other ideas? Thanx for the help in advance
Hazenson Posted May 21, 2010 Author Posted May 21, 2010 I figured that ground must be ok- cuz they ground right to the frame and the other lights run off that ground
Ponch Posted May 21, 2010 Posted May 21, 2010 Check the wire connections. If you used Scotchlok's to splice the wires together, they sometimes do not make a good connection.
Hazenson Posted May 22, 2010 Author Posted May 22, 2010 Figured it out, with a tester I found I was getting juice to the trailer modulator brown line-(running lights) but not coming out the other side. I musta fried it inside. So I added a short wire and bypassed it. Everything seems to be working fine now.
