Has anyone changed their speakers? I am sure a lot of you have.
I am thinking of replacing the speakers with decent 2 way speakers for better highs and midrange. Damn, no place for a sub! ;)
Has anyone ever added an amplifier? I am thinking of a small sized 100 watt amp (4 x 25). Is there a decent quality small compact sized amp that can be used on the Venture? Would it be relatively easy to hook up?
Looking forward to your replies.
Greg
Check out this topic area. You will find a couple of articles on amps and etc.
http://www.venturerider.org/forum/forumdisplay.php?f=74
Thanks Freebird. Shortly after I posted my question, I found your post with instructions. I am assuming with an amp like this and better speakers, I will be able to hear music a lot better on the highway. Is it really worth the money / effort?
Later,
Greg
Later,
Greg
Ive got theese 105 watt peak speakers http://www.crutchfield.com/S-u9ySPYDBbI8/App/Product/Item/Main.aspx?g=51200&tab=essential_info&i=107DB400
along with a 200 watt marine stereo.
No trouvle hearing the tunes at any speed. Of course i dont have loud pipe on my ride. id like to add 2 more speaker in the rear when i have time. the 2nd gens have rear speakers right?
Thanks Mike. Polk is supposed to be a good speaker.
Greg
The amp and speakers help but still not as much as I would like. We REALLY need a subwoofer to get more bass.
Could always put a sub on the passenger seat. :rotf:
Think the wife would understand? :no-no-no:
Greg
These are the ones I happen to purchase as well. They sound excellent! And they are marine grade, so they are weatherproof.
Greg
There is a member, can't remember who right now, who has a picture in their gallery of a subwoofer in the trunk of his 2nd gen. Takes up all the space in the trunk though. Of course, probably rattles ever screw, in the trunk, loose. Better use red loc-tite if you're gonna put it there.
I would never put a sub in the trunk. I think with good quality 2 way speakers and a small amp the sound should be way better than stock and louder than stock for highway listening. I am going to make sure that the 2 way speakers have a built in crossover to separate the highs so only the highs hit the tweeter. Good quality speakers will also have a larger magnet.
Greg
Watch out for those larger magnets. Fine for the front but the first that I tried for the rear were a set of Alpines. The pods/armrests would not go together because the magnets were too large.
Thanks for the tip Freebird. Never thought of that.
Greg
I have to agree that with more efficient speakers there is a definate need for better bass. Physics is physics and to get good bas you have to move a large volume of air, which ain't gonna happen with 4" speakers. The problem being with updated speakers you get enhanced highs but no bottom end to go with it.
Yes, I have contemplated down firing a woofer or two inside the seat...
