DELSURFIN Posted March 18, 2010 Posted March 18, 2010 Lost my rear brakes on the way to work this AM. Looks like fluid spray on the rear tire--no rear brake pedal. Front brakes still working. Safe to drive carefully to the shop (10 miles)? Thank you ED
Eck Posted March 18, 2010 Posted March 18, 2010 Yes, you can ride it 10 plus miles safely using just the front brakes, by providing extra stopping space and using good cautionary riding skills. Sounds like the caliper is leaking, or you have a hole in the brake hose / line.
DELSURFIN Posted March 18, 2010 Author Posted March 18, 2010 Thank you. I wasn't sure if the front brake had a seperate fluid cylinder and was concerned I may lose the front brakes from the rear leak. ED
Guest human4m Posted March 18, 2010 Posted March 18, 2010 I would think so, just BE CAREFUL! If there's brake fluid on the rear tire, be ready for a fish-tailin' fun time! As long as you're covering the front brake, and taking it REALLY easy, I think it'd be fine to go 10 miles to the shop. Then again, this is more of a personal judgement call than a a question that should be answered by opinion.
LilBeaver Posted March 18, 2010 Posted March 18, 2010 If it is still leaking (and there is fluid left in the reservoir) it may be worth pumping/removing the rest of the fluid from the rear brake system to keep brake fluid off that rear tire and from ruining any painted or plastic surface that it might find its way to. If it is a busted hose/brake line you could always wrap it up with a napkin, paper towel or packing tape or something - just to keep the spray down/contained...
