Hummingbird Posted March 14, 2010 #1 Posted March 14, 2010 Presently, on my Venture I have both 'frost plugs' drilled out completely in the RK muffs. It's fairly loud when accelerating but quite tolerable when cruising, I'm wondering if anybody has just one 'frost plug' removed and which end did you remove ? I have a bit that will remove all of the plug and makes a real nice clean hole.
SilvrT Posted March 14, 2010 #2 Posted March 14, 2010 Adventure 1943 said: Presently, on my Venture I have both 'frost plugs' drilled out completely in the RK muffs. It's fairly loud when accelerating but quite tolerable when cruising, I'm wondering if anybody has just one 'frost plug' removed and which end did you remove ? I have a bit that will remove all of the plug and makes a real nice clean hole. I tried it with just one (from the aft end) drilled out. Wasn't enuf for me... I then drilled out all 3 and really like them now.
Hummingbird Posted April 16, 2010 Author #3 Posted April 16, 2010 SilvrT said: I tried it with just one (from the aft end) drilled out. Wasn't enuf for me... I then drilled out all 3 and really like them now. Been a while but I just re-read this - where did you find a 3rd plug ?
SilvrT Posted April 16, 2010 #4 Posted April 16, 2010 Adventure 1943 said: Been a while but I just re-read this - where did you find a 3rd plug ? There was one in the middle and one close to each end.
Sailor Posted April 16, 2010 #5 Posted April 16, 2010 (edited) Where are these "frost plugs" located? I looked on the diagram and could not see any listed. Edited April 17, 2010 by Sailor
SilvrT Posted April 16, 2010 #6 Posted April 16, 2010 Sailor said: Where are these "frost plugs" located? I looked on the diagram and could not see any listed. Diagram??? He's referring to the baffles inside the RK mufflers (I believe). They are nothing more than a round metal "plug" about the size of a Loonie (silver dollar for you US guys LOL) inside the muffler. There is an internal "tube" that runs lengthwise in the muffler and the baffles force the exhaust to the inside of the muffler (so to speak). When you drill out the baffles, the exhaust is almost straight-thru although some still gets muffled. In my RK's, there were 3 of these baffles...one near the inlet, one near the outlet, and one in the middle.
Sailor Posted April 17, 2010 #7 Posted April 17, 2010 (edited) OK,baffles I understand. "Frost Plugs" had me baffled. Edited April 17, 2010 by Sailor
Hummingbird Posted April 17, 2010 Author #8 Posted April 17, 2010 I only had 2 "plugs" on my RK's - one on each end - takes quite a long shaft to reach the middle
SilvrT Posted April 17, 2010 #9 Posted April 17, 2010 Adventure 1943 said: I only had 2 "plugs" on my RK's - one on each end - takes quite a long shaft to reach the middle heh ... (nope... ain't gonna say nuffin!)
