naturbar Posted December 13, 2009 Share #1 Posted December 13, 2009 i've posted this request in the Watering Hole and considering my request is about RSTD i thought i would post here as well. i have an 07 midnight RSTD and was instalingl passing lamp mount bar part # STR-1D635-40-00 and found that i cannot fit my OEM flasher lamp onto the special bolt which is provided with the mount bar kit. the mount bolt is .020 (20 thousandth) larger in diameter than the flasher lamp mount hole (with rubber sleeve removed). no way it will fit. anyone here with an 07 that has done the passing lamp mod and if so could you provide me with the part numbers you used to do the job....thanks....HELP !! Merry Christmas to all ........ buz Link to comment Share on other sites More sharing options...
jrsc4excel Posted December 13, 2009 Share #2 Posted December 13, 2009 I will assume that you have loosened the bolt on the pinch ring as much as possible. A set that I installed once I had to pry it open slightly while installing them to get it to slid over for me. Link to comment Share on other sites More sharing options...
naturbar Posted December 13, 2009 Author Share #3 Posted December 13, 2009 Pecker suggested a solution and it worked - so thanks for any & all input. merry Christmas to all............. Link to comment Share on other sites More sharing options...
RandyR Posted December 13, 2009 Share #4 Posted December 13, 2009 Glad it worked. I've got a set in the box ready to go on... Link to comment Share on other sites More sharing options...
starkruzen Posted December 25, 2009 Share #5 Posted December 25, 2009 HMMM, wife just got me a pair of passing lights and all went on without a hitch. The blinker lights are a tight fit, but they went on okay. Best of luck! Link to comment Share on other sites More sharing options...
