Aussie Annie Posted November 2, 2009 Posted November 2, 2009 Someone with a XVZ1300 (naked) over here asked me if I knew the valve settings. Nope, but knew where to come and ask:thumbsup2: So help away guys.......................................
BuddyRich Posted November 2, 2009 Posted November 2, 2009 If its a second gen just look in your trunk. There's a label on your's that has the tolerances.
Aussie Annie Posted November 2, 2009 Author Posted November 2, 2009 Nope, just looked and all I got is tire info sticker. Valve setting info label must be in the same box as the CB I never got! (and it's 2nd Gen)
RandyR Posted November 2, 2009 Posted November 2, 2009 Intake .11 to.15 Exhaust .16 to .20mm measured when cold Your friend should download the Maintenance Specifications .pdf file in the tech library. There's also a thread in the tech section here on how to check and replace shims if necessary.
