bobcat Posted September 3, 2009 #1 Posted September 3, 2009 Today for the first time my bike started backfiring on deceleration...these were not the usual rumbling or small pops I normally heard when coming down a mountain road but rather loud backfires..It did it both in 3rd and 4th gear at about 4000rpm decelerating to 3000 rpm..I thought it might be due to altitude but it did it at lower elevations also... I did the needle modification to lean out the bike, could that be causing it? All else is good..starts and runs fine..alls good except the backfiring..
Venturous Randy Posted September 3, 2009 #2 Posted September 3, 2009 The decelleration pops are usually associated with an exhaust leak. That same leak is pulling in oxygen, allowing the pop. RandyA
CrazyHorse Posted September 3, 2009 #3 Posted September 3, 2009 I had a nipple cover come off the syncro attachments sucking in air and causing backfire.
shouldi Posted September 3, 2009 #4 Posted September 3, 2009 that is a lean condition, did you ever hear the old 900, and 1000 kawasakis do that after guys put on an header years ago, they didn`t jet the bike right, go back to the original jetting, maybe even raise the needle, put the washer under the clip
bobcat Posted September 3, 2009 Author #5 Posted September 3, 2009 Jimbob5 said: I had a nipple cover come off the syncro attachments sucking in air and causing backfire. I'll be dipped in sh**...you hit it right on the head..After reading your post I thought what the heck might as well check those nipples before going any further and sure enough the R/F carb was missing a nipple....Thanks for saving me the anguish of trying to figure out why the backfiring... I owe you a few beers if we ever meet...
shikano53 Posted April 12, 2011 #6 Posted April 12, 2011 bobcat said: I'll be dipped in sh**...you hit it right on the head..After reading your post I thought what the heck might as well check those nipples before going any further and sure enough the R/F carb was missing a nipple....Thanks for saving me the anguish of trying to figure out why the backfiring... I owe you a few beers if we ever meet... Where are those nipples located? I should the ones on my bike as well. Thanks Chris
SilvrT Posted April 12, 2011 #7 Posted April 12, 2011 shikano53 said: Where are those nipples located? I should the ones on my bike as well. Thanks Chris just look at the base of the carbs where the intake tubes are ... hard to miss... unless they're missing LOL
