N3FOL Posted April 14, 2009 Share #1 Posted April 14, 2009 (edited) I won this used License Plate Holder with Lights (Item# 170318869042) and I am wondering if there is an LED lamp available bright enough for the application (68230-97b). What would be the color of the wire I should be looking for inside the license plate holder area to connect to the assembly? Is this a straight bolt on? Tips please. Edited April 14, 2009 by N3FOL Link to comment Share on other sites More sharing options...
cecdoo Posted April 14, 2009 Share #2 Posted April 14, 2009 I couldnt open your link so I cant see what ya won, I put an led lisc. plate holder on my bike. Behind the plate you tie into the Blue wire for running lites and yellow wire for brake lite. Mine was a very easy swap, I just slid the connectors apart put new wire in female connector and slid male in to clamp new wire in, no splices. Craig Link to comment Share on other sites More sharing options...
N3FOL Posted April 14, 2009 Author Share #3 Posted April 14, 2009 http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=170318869042&sspagename=STRK%3AMEWNX%3AIT&viewitem= Hope this link works. Link to comment Share on other sites More sharing options...
N3FOL Posted April 14, 2009 Author Share #4 Posted April 14, 2009 Not sure why the link that I add is no longer there. I just completed the transaction and paid for it today. Perhaps you can search eBay via the Item #. It is the Harley Touring Light Chrome Rear Auxilliary Light Link to comment Share on other sites More sharing options...
N3FOL Posted April 14, 2009 Author Share #5 Posted April 14, 2009 I couldnt open your link so I cant see what ya won, I put an led lisc. plate holder on my bike. Behind the plate you tie into the Blue wire for running lites and yellow wire for brake lite. Mine was a very easy swap, I just slid the connectors apart put new wire in female connector and slid male in to clamp new wire in, no splices. Craig Hello Craig. Are the wires located right on the plate holder? Have not really looked until I remove the plate holder on my '07. Link to comment Share on other sites More sharing options...
cecdoo Posted April 14, 2009 Share #6 Posted April 14, 2009 Hello Craig. Are the wires located right on the plate holder? Have not really looked until I remove the plate holder on my '07. Ok thats not the one I used, but have you checked the second gen tech section, I think there is a writeup on installing the Harley lites. If you look at your rear fender from the side, behind the Lic plate you will see a chrome bump out-all the wires are in there, tightly coiled up, you just need to carefully separate them and work on one at a time, guess you are gonna need wire colors for turn signals as well. Craig Link to comment Share on other sites More sharing options...
N3FOL Posted April 14, 2009 Author Share #7 Posted April 14, 2009 Craig, I just intend to use these lights are Run and Brake Lights only. From your reply, I will just look for the Blue and Yellow wire on the RSV...but I need to verify which color wire is the Run and Brake wires on the Harley 68230-97b. Thank You. Link to comment Share on other sites More sharing options...
N3FOL Posted April 15, 2009 Author Share #8 Posted April 15, 2009 Does anyone know what kind of LED lamp I should order to replace the bulbs on the Harley Aux Light part # 68230-97B? I think the assembly takes an 1157 type bulb...I've seen a few on the CustomDynamics website, but still unsure. Link to comment Share on other sites More sharing options...
N3FOL Posted April 20, 2009 Author Share #9 Posted April 20, 2009 This is what I won on eBay...http://i22.ebayimg.com/07/i/000/7f/cb/2731_2.JPG This is what I plan to order from Custom Dynamics...http://www.customdynamics.com/Images/genesis_180_led_small.jpg Size: 1.25" or 1.80" Dynamic Replacement Cluster. I am leaning towards the 1.80" which may fit. Any recommendations? Link to comment Share on other sites More sharing options...
N3FOL Posted April 21, 2009 Author Share #10 Posted April 21, 2009 I think I hit a bump here. Link to comment Share on other sites More sharing options...
KiteSquid Posted April 21, 2009 Share #11 Posted April 21, 2009 Yep, you shure did. I would recomed you buy the one that fits that puts out more light. Link to comment Share on other sites More sharing options...
N3FOL Posted April 21, 2009 Author Share #12 Posted April 21, 2009 Thanks KiteSquid. I will have to triple check the bulb that came with the assembly. The last time I looked, it is an 1157 bulb with contacts on the same plane at 180° of each other...Not Offset and the bottom of the bulb has 2 contacts. This tells me that it is a dual 1157. Most places say that an 1157 bulb will have an offset contact and has two point of contact on the bottom. I think it has an older type 1157 bulb. Link to comment Share on other sites More sharing options...
KiteSquid Posted April 21, 2009 Share #13 Posted April 21, 2009 Does the bulb that came out of the assembly have any nubers on it??? They might be on the glass or on the base. Link to comment Share on other sites More sharing options...
N3FOL Posted April 23, 2009 Author Share #14 Posted April 23, 2009 My apologies...I guess from the last time I checked the old bulb, it looked like an 1157 with no Offset on the side contacts. I was in a hurry to get to work. Last night, I just confirmed that it is an 1157 with an Offsetted side contact. I ordered the 1.80" LED clusters that should fit the housing. This afternoon, I may go ahead and install the Aux Light/Tag holder. Link to comment Share on other sites More sharing options...
