cody stewart Posted August 5, 2007 Posted August 5, 2007 i have the 07 the manual says you can air the shocks up and tells psi but says o is standard. if this is right normal riding is ok at 0 are should i air them up?
gibvel Posted August 5, 2007 Posted August 5, 2007 A lot of people here leave the front forks at 0, some keep them at about 5 psi. As far as the rear shock goes, I think 30 is "Normal" for 1 up and then they adjust for 2 up. However, the way the bike rides and handles is a personal preference thing and you should just play around and see what you like best.
cody stewart Posted August 6, 2007 Author Posted August 6, 2007 thanks for replying I have been running the rear at 0 and like the way she rides but the book did not say to add air so I just wanted to be sure it was all aright to do it that way.
James Ardrey Posted August 6, 2007 Posted August 6, 2007 It's been my experience that 5# in front and at least 30 in back make the bike much more responsive and improves handling at all speeds especially curves and more stable coming to a stop due to less front shock travel stopping in a straight line. It is much more noticable with 2 up. As previous response you won't know what it can do for you till you experiment yourself.
Mean Dog Posted August 6, 2007 Posted August 6, 2007 I keep 5 lbs in the front and 30 lb in the rear riding single and 40 lb if riding double or pulling the trailer. 0 lb will bottom out with me riding single at the 330 lbs that I am......LOL. http://smileys.smileycentral.com/cat/36/36_19_2.gif Dog
cody stewart Posted August 6, 2007 Author Posted August 6, 2007 thanks guys I am a little bit slow on this thing but I appreciate the advice.my wife and I rode it at 0 in Colorado and it rode good and smooth. but I think it needs a little more in back with her on.I did not know if it would hurt with no air in it?
OB-1 Posted August 8, 2007 Posted August 8, 2007 I run 7 psi in the forks and 55 psi in the rear shock.
sarges46 Posted August 8, 2007 Posted August 8, 2007 Remember....hand pumps only to air up the shocks. Get a good one ....like progressive or similar.
