StuD Posted March 3, 2009 Share #1 Posted March 3, 2009 Somebody "pre-crash" posted a fix for pins broken off of fairing. I've searched, cant find it, hope its not lost. If memory serves it was a metal grease nipple gizmo........yikes......help..:canada: Link to comment Share on other sites More sharing options...
Eck Posted March 3, 2009 Share #2 Posted March 3, 2009 (edited) I think this is what your asking for.... http://www.venturerider.org/forum/showthread.php?t=20293 If not, how about this... http://www.venturerider.org/forum/showthread.php?t=516 Edited March 3, 2009 by Eck Link to comment Share on other sites More sharing options...
6m459 Posted March 3, 2009 Share #3 Posted March 3, 2009 http://www.venturerider.org/forum/showthread.php?t=8181 Link to comment Share on other sites More sharing options...
Venturous Randy Posted March 3, 2009 Share #4 Posted March 3, 2009 The best fix I have found is Industrial Strength Velcro. Clean both surfaces and put the Velcro on and it works great. RandyA Link to comment Share on other sites More sharing options...
CrazyHorse Posted March 3, 2009 Share #5 Posted March 3, 2009 I still had the broken pins stuck in the rubber holder. I abs glued them and then drilled thru them and put the machine screw thru it and tied into a small nut on the bottom that was loctited. Link to comment Share on other sites More sharing options...
bobcat Posted March 3, 2009 Share #6 Posted March 3, 2009 Stud...I completely remove the old nipple from the base..I then drill the appropriate sized hole in the base and install a 5mm allen head screw that I nut on both sides of the base...The allen head is about the same size as the plastic nipple head and fits nicely in the rubber grommet.... Link to comment Share on other sites More sharing options...
StuD Posted March 3, 2009 Author Share #7 Posted March 3, 2009 Stud...I completely remove the old nipple from the base..I then drill the appropriate sized hole in the base and install a 5mm allen head screw that I nut on both sides of the base...The allen head is about the same size as the plastic nipple head and fits nicely in the rubber grommet.... I have that tecknolegy I'll give it a go Thanks :canada: Link to comment Share on other sites More sharing options...
