Kregerdoodle Posted January 18, 2009 Posted January 18, 2009 Not sure if I have a problem or not, it looks like one side of my front tire is on the road more then the other, if that makes sense, but I measured it from the center and the wear is equal, it looks off to me, what do ya`ll think??
V7Goose Posted January 18, 2009 Posted January 18, 2009 Well, you can't really tell much from a dirt pattern on the tread - that could simply be because you have a dirt driveway with a right curve in it, or even just a dirty approach to your garage. Bike tires in countries where we ride on the right side do tend to wear more on the LEFT side of the tire (opposite your pictures), but you can't really tell that until the tread gets near the end of its life. I have posted pictures and information on this in the past. The reason for the excess left-side wear is not really known, but speculation suggests a combination of the road crown and longer arcs in left turns compared to right turns. I don't think you have anything to worry about unless you have a worn out tire that clearly shows less rubber left on the right side instead of the left. If that happens, you need to look at frame alignment and excessive weight distribution problems. Goose
Eck Posted January 18, 2009 Posted January 18, 2009 I would take several measurements of tread depth in both directions from the center line towards the rim edge. These measurements would be taken in several places around the tire, then The patteren of measurements would tell if you are out of (or off) center.. Dont go by the dirt lines on the tread as V7Goose mentioned.. I agree you cant judge the tread depth or wear patteren by the dirt lines
Sleeperhawk Posted January 18, 2009 Posted January 18, 2009 You just need to find some twisties and stay off those long straight Texas roads.
Kregerdoodle Posted January 19, 2009 Author Posted January 19, 2009 Thanks alot for all the input, Gunboat ( Don ) came out today and he looked at also, if you look beyond the dirt you can see the actual wear marks on the tires, and they are pretty much the same.. I just wasn`t sure so wanted to bring it up to the pro`s on the site. Thanks again! Kreg
