Anybody else ever have a problem with their tach making noise? At first I thought my speedo needed to be greased again. I greased the speedo and the noise was still there. It would come and go but not stay gone. Then I noticed that when I engaged the clutch when going down the road the noise stopped. I hit the throttle and it came back. Then I had a "DUH!" moment and realized it was the tach making the annoying noise. :doh:
The tachometer is electronic. Nothing really moves except the needle. I think it's unlikely that the noise is coming from there.
What about parked, in neutral? The tachometer doesn't care if you are moving or not.
Yep, I agree with carl on this one.
RandyA
Yup, moving, sitting still, doesn't matter. I hit the throttle and it makes noise. I would imagine there is a motor or something that spins the needle, (dunno, never had to take one apart), and that's where the problem is. It still works, but it's annoying on a quiet drive down the back roads.
