Anybody with a RSTD have the Protac drivers backrest? I picked one up used but just can't see how it connects to rear fender. Just won't line up. Does it go behind the chromepiece for the saddlebags? Pics would be helpful. God Bless. Mike
I bought one for my wifes bike (Virago).
The backrest comes with two brackets that mount to the bike. The bracket has pipe welded to it and the bar backrest slides into the pipe.
Check out the web site and you can see the brackets if you look closely.
http://www.protac.net/9243.html
Regards,
Brad
On the Virago, I slide the chrome shock of the bolt, then installed the plate (supplied with back rest), and then reinstalled the shock and nut.
I did not think they made one for the Venture.
Suggest sending them an email, or call them. I am sure they would send you the instructions just a simple page. They were real nice people and very helpful. Replaced the chrome bar on the backrest, without questions. Real quick to respond as well.
Good luck
Brad
Here's the response from Protac and a picture. Mike This picture show the black bracket but not too well. It is about 5 inches long. It bolts to the front bolt of the rear fender rail, the tube is welded to the front and has a 12 degree forward tilt. The royal star prior to 2005 was a long bracket that used the front and rear bolt to attach. The Venture and the Royal Tour deluxe 2005 and up takes the same backrest. Harold
I got to give it to a company that responds to questions about used products and not just new quickly.
Installed. Actually very easy and straight forward. I didn't like the metal to metal notion so I put electrical tape between with flat rubber washer and threadlock. After putting on brackets, the backrest just drops right in. Now to find the leveling links I bought and lost somewhere in this mess. Brake pads ordered and coming, I WANT SPRING!!!
AS I said they were great to deal with Very fast with right answers. They answered me within a few hours on a Sunday.
Glad it worked for you. :thumbsup2:
Brad
I had one on a Honda Shadow I used to have.Took it to a machine shop and had a hole
drilled in each bracket and tapped to install 1/4 inch pipe plug with allen heads.Makes the
backrest more stable and not move around and also where some one couldn't just pull
it out and walk off with it. Could not understand why they didn't do that from the factory.
