clutch questions
Dark Wolf
I just replaced the clutch on my 87 with a barnett clutch , it was around 130.00 for the friction plates. If your metal plates are ok and don't have burn marks on them you would be good to go. Check the 1st. gen tech section , there is a barnett clutch install post that tells all you need to know. pretty easy to do. :thumbsup:
I've found through the years that the Yamaha dealer is about a good a place as any for the fiber disc and about the same price.
I actually have never heard any bad things about any companies disc.
Good Luck,
Jerry
