Dark Wolf Posted October 31, 2008 #1 Posted October 31, 2008 I am about to replace the clutch on my 83VR. Wondering if I could get some input on what type or brand I should be looking at.
capn eddie Posted October 31, 2008 #2 Posted October 31, 2008 I just replaced the clutch on my 87 with a barnett clutch , it was around 130.00 for the friction plates. If your metal plates are ok and don't have burn marks on them you would be good to go. Check the 1st. gen tech section , there is a barnett clutch install post that tells all you need to know. pretty easy to do.
BOO Posted October 31, 2008 #3 Posted October 31, 2008 I've found through the years that the Yamaha dealer is about a good a place as any for the fiber disc and about the same price. I actually have never heard any bad things about any companies disc. Good Luck, Jerry
