skidmark Posted September 29, 2008 Posted September 29, 2008 Hi i tried looking on Google no results i have a oil light on the screen and warning light blinking check oil level ok i was hoping the manual would help figure this out , or maybe one you guys could help me out Thanks in Advance Skidmark !!
chabicheka Posted September 29, 2008 Posted September 29, 2008 http://labs.trunkful.com/8385servicemanual.pdf
Condor Posted September 29, 2008 Posted September 29, 2008 Downloadable manuals are available here. http://www.venturerider.org/forum/showthread.php?t=3384 Check your sight glass on the side of the engine. You may be low on engine oil. Level should be between the top and bottom lines.
Venturous Randy Posted September 29, 2008 Posted September 29, 2008 Downloadable manuals are available here. http://www.venturerider.org/forum/showthread.php?t=3384 Check your sight glass on the side of the engine. You may be low on engine oil. Level should be between the top and bottom lines. with the bike on the center stand. RandyA
skidmark Posted September 29, 2008 Author Posted September 29, 2008 oils full so i guess i must trace the wire make sure its hooked up any other options ? Thanks for all the responses
PEIslander Posted September 29, 2008 Posted September 29, 2008 Hey Skidmark, Some of us have mistaken the low brake fluid light for a low oil. On the dash readout the top left indicator is sidestand, the one below it is low brake fluid and the one below that is low oil. If its brake fluid it could be either front or rear resevoir low. When I got my bike a few years ago the light would come on when I was accelerating hard and I thought it was oil but it turned out to be the front brake resevoir. The low oil indicator looks like an old oil can and the brake fluid looks like this (O) with a drop in the middle of the O. ( I tried to attach a picture but couldn't) . The picture of the dash monitor is on page 8 in the manual http://labs.trunkful.com/8385servicemanual.pdf Good Luck Rick
skidmark Posted September 29, 2008 Author Posted September 29, 2008 Thanks PEI thats it ......... ( hangs his head low while waking away :-) good call thanks a lot !! Joe
PEIslander Posted September 30, 2008 Posted September 30, 2008 No sweat, We're all learning from each other on this site. I felt a bit silly myself when it happened to me but in retrospect the symbols Yamaha used aren't very good so we'll blame them.
