Ken Parker Posted September 27, 2008 Share #1 Posted September 27, 2008 Two days prior to hurricane Ike hitting here, I pulled the tank off my '05 RSV and changed the plugs, while I had the tank off I also changed out the coolant and cleaned the reservoir. I also went ahead and changed the oil and filter. Anyway during this time the storm hit and needless to say my attention got diverted from my task of completing the maint. I work in one of the Chemical plants here on the shipchannel and just the other day after two weeks I got the bike back together. Heres is the problem, it hs started back-firing rather badly after it geets good and warm (when down-shifting). After looking at a parts manual I see that there is a roll over valve I do not think that I reattached the hose from the tank to the valve. I really don't remember even taking it loose. Could this be causing the problem? Plugs were replaced with same type and #, no contamination of fuel. So I am stumped, what do ya'll think? Link to comment Share on other sites More sharing options...
Tom Posted September 27, 2008 Share #2 Posted September 27, 2008 I dont mean to be a smarta$$ but could you have pulled the choke knob out a little and its not back in all the way..Yep,I did that once! Tom Link to comment Share on other sites More sharing options...
Ken Parker Posted September 27, 2008 Author Share #3 Posted September 27, 2008 Possibly I guess but it seems to idle great, I'll check that when I get home in the morning. Link to comment Share on other sites More sharing options...
Neil86 Posted September 27, 2008 Share #4 Posted September 27, 2008 Spark plug caps down tight on plug? Any chance the air intake ducts to carbs are loose? Link to comment Share on other sites More sharing options...
V7Goose Posted September 27, 2008 Share #5 Posted September 27, 2008 You have a vacuum leak somewhere. Either you disconnected a hose and didn't get it back, jostled the carbs a bit loose on the manifolds, or it is just coincidence that the vacuum caps started leaking bad at this time. Frankly, unless you have changed them, they are way past due to leak bad on an 05. Goose Link to comment Share on other sites More sharing options...
Ken Parker Posted September 30, 2008 Author Share #6 Posted September 30, 2008 Tom you were right the chock throttle was loose causing it to be out ever so slightly, thanks that suggestion saved me alot of time and troubleshooting. Link to comment Share on other sites More sharing options...
