VentureRider.Org Cruiser Customizing
Home Venture History Classifieds Links VRAwards VRPhotos VRChat VRStore Donate
Go Back   VentureRider.Org > Tech Talk > First Generation Venture Tech Talk
User's Login
User Name
Password
Remember Me?
Mini Stats
Members 12,857 Entries 0
Members Entries
Threads 52,720 Reviews 0
Threads Reviews
Posts 628,416 Polls 46
Posts Polls
Content 0 Files 0
Content Files
Links 64 Ads 0
Links Ads
More...
  #1
Old 08-18-2012, 07:45 PM
jimc1031 jimc1031 is offline
Default 1987 Venture With Transmission Problems
I am a newbie ! Just purchased a 1987 Venture 'i bought it cheap-but probably not cheap if
My problems are more than the seller had a so called motorcycle mechanic tell him that it needed
A clutch ???WHEN TURNING THE ENGINE OVER WITH WRENCH ON FLYWHEEL IN GEAR HAS A POPPING
NOISE ON LEFT SIDE OF TRANS-IT DOES NOT MATTER WHAT GEAR IT IS IN DOES NOT ROTATE DRIVESHAFT OR UJOINT ???
I have studied the trans diagrams ,it appears to me either spring loaded cog is messed up or has a broken spring. ?????
Please give a feed back on this-i am new to these bikes-YOU GUYS KNOW MORE THAN ME ON THIS
PLEASE HELP- THANK YOU. JIM
  #2
Old 08-18-2012, 08:26 PM
Yammer Dan's Avatar
Yammer Dan Yammer Dan is online now
Supporting Member
Supporting Member
Default
There is u joint that connects the tranny to the driveshaft. Old timers kicking in can!t think of the name of it. Sounds like this could be your problem.
__________________
1st GENS RULE
Faded Blue is the fastest.
"Blue Beast" will live forever
The Following User Says Thank You to Yammer Dan For This Useful Post:
  #3
Old 08-18-2012, 09:33 PM
friesman's Avatar
friesman friesman is offline
2003 RSV
friesman has a Profile Picture
Supporting Member
Location: Find friesman on Google Maps! Regina Saskatchewan Canada
Default
My 85 snapped the shaft just in front of the ujoint, right where the shaft exits the back of the engine and it kind sounded like a pop when spun at slow speed.
Welcome to the nut house,..... Good luck with the bike, they are relaiable and mostly trouble free, but there are issues occasionally like anything...
Brian
__________________
The Following User Says Thank You to friesman For This Useful Post:
  #4
Old 08-18-2012, 09:35 PM
MiCarl's Avatar
MiCarl MiCarl is offline
1989 Venture Royale
Supporting Member
Location: Find MiCarl on Google Maps! Livonia (Metro Detroit)
Default
Sounds like middle gears chewed up, or bad splines on the output shaft.. That's the one that changes the drive direction from cross ways (way engine turns) to long ways (drive shaft direction).
If you pull the rear case cover on the left side you can see the shaft for the horizontal gear. If it's turning and the drive shaft isn't then you know the problem is at the middle gear/output shaft.
I believe it can be serviced without splitting the cases, maybe even in frame. Someone here has done it, I've seen the pictures.
__________________
1989 Venture Royale
1982 XJ650 (Sold)
The Following User Says Thank You to MiCarl For This Useful Post:
  #5
Old 08-18-2012, 09:51 PM
dingy's Avatar
dingy dingy is offline
83 1st Gen, 03 RSV Hybrid
dingy has a Profile Picture
Supporting Member
Default
I have a 1300 motor I am rebuilding and it had the rear bevel gear that Micarl mentioned tore up. The bevel gear on the transmission shaft looks OK, which is surprising. This bevel gear has the u-joint on the other side. It can be pulled with motor in the frame after removing rear wheel & swing arm. Any more than this and the motor needs to come out of frame.
The thing about having this kind of damage is that there could be other issues that caused this condition. In the case of this motor, one of the bearings on the output tranny shaft had the cage come apart which would have been a far worse problem if not caught in time.
Gary
__________________
Venture Maximized
VMax
The Following User Says Thank You to dingy For This Useful Post:
  #6
Old 08-18-2012, 11:35 PM
Default 1987 Venture With Transmission Problems ???
Thanks everyone for the reply-tomorrow I will remove the pinion gear
Jim -in
Nevada- Will respond to let you know !!!
  #7
Old 08-20-2012, 11:17 PM
Quote:
Jim -in
Today I remove the middle gear-middle gear and ring gear ok-FOUND THE SPRING LOADED COG GEAR
THAT GOES INTO RING GEAR BUSTED INTO ABOUT 4 PIECES
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Venture line backrest, 1987 showmebob First Generation Venture Tech Talk 18 11-21-2012 02:52 PM
transmission problems -too much backlash jimc1031 GPS, Audio, Electronics 1 08-25-2012 02:07 AM
should i use a lead substitute in fuel in a 1987 yamaha venture jman First Generation Venture Tech Talk 9 07-01-2012 02:47 PM
Peg Lowers for 1987 Yamaha XVZ13DTC VENTURE JakeBean First Generation Venture Tech Talk 6 12-14-2009 09:22 PM
1987 Venture Royale For Sale. RoadKill Watering Hole 0 03-18-2008 08:58 AM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
Copyright 2004 VentureRider.org
