rmcclain Posted June 23, 2009 Share #1 Posted June 23, 2009 I just installed a new Firestik antenna and fold down bracket. I am in the garage and cannot get reception on either the radio or CB. I can hear static in the speakers. Is the problem that I am inside the garage? Link to comment Share on other sites More sharing options...
BOO Posted June 23, 2009 Share #2 Posted June 23, 2009 I doubt it, should get something on both radio's. Maybe the antenna lead is grounded to the frame somehow. Most obvious is, is the antenna connected? BOO Link to comment Share on other sites More sharing options...
Gearhead Posted June 24, 2009 Share #3 Posted June 24, 2009 As mentioned above, antenna grounded to frame is a no-no. There is a special nylon shoulder washer to prevent this - do you have yours mounted properly? Disconnect the antenna lead and then use an ohmmeter between the antenna's metal base and the bracket - there should be no continuity. Did you use a "splitter"? Jeremy Link to comment Share on other sites More sharing options...
