User Tag List
Results 1 to 6 of 6
Thread: Side stand.
  1. #1
    Join Date
    May 2016
    Menasha
    WI
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Default Side stand.
    So my side stand cracked and didn't completely brake because my leg just happened to be there to stop Lucy from going all the way down. Was wondering about things to check when replacing the stand. What else could be worn or bent? What other parts might need to be replaced? Can the stand be repaired or do I have to replace it? Where is a good place to get a new one? As it is now, just the lower ear (I guess that would be what it is called) is cracked and the top ear is bent.
    Ride for the love of the road and the freedom it offers.
  2. #2
    Join Date
    May 2008
    Rochester, NY
    NY
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Side stand.
    There is a modification that can be done to eliminate this problem. Past member Dingy designed it, Very simple and cheap.
    http://www.venturerider.org/forum/sh...ad.php?t=48342
    Jim
    Don will need to restore the photos.
    Life is too short to drink bad wine.
  3. Thanks Air Ready Auto gave thanks for this post
    Likes ShinySideUp liked this post
  4. #3
    Join Date
    Aug 2006
    Oberlin, OH
    OH
    Post Thanks / Like
    Mentioned
    119 Post(s)
    Tagged
    0 Thread(s)
    Photos restored.
  5. #4
    Join Date
    Jun 2007
    Cudahy, WI
    WI
    Post Thanks / Like
    Mentioned
    203 Post(s)
    Tagged
    0 Thread(s)
    There are a bunch of them on ebay right now.
    just search for it by P/N. 26H-27311-01-R4
    https://www.ebay.com/itm/YAMAHA-1983...oAAOSww-BaapGi
    There have been several posts in the last couple of months warning people to check this before it breaks.
    Jeff Borowski . . 88 Venture standard
    There are 10 kinds of people that understand binary, those that do, and those that don't. Sometimes the thoughts in my head get bored and go for a stroll out through my mouth (or fingers). This is never a good thing.
  6. Thanks Air Ready Auto gave thanks for this post
  7. #5
    Join Date
    Mar 2017
    Papillion
    NE
    Post Thanks / Like
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Flyinfool View Post
    I have inspected mine and can't find anything visually wrong but sometimes it feels like it's leaning quite a ways and you all are making me paranoid now! How much lean is normal? When I put the kickstand down and lean it over till it makes contact with the ground the only motion that takes place is the rising of the bike when I get off of it and the suspension goes to its resting position. There is no movement outward or wiggling at the joint. Well, other than the spring load that allows it to move towards the bike or ground when I push on it but no outward movement which would cause a tip over . Can I assume it's solid?
    Sent from my SM-G935V using Tapatalk
  8. #6
    Join Date
    Jun 2007
    Cudahy, WI
    WI
    Post Thanks / Like
    Mentioned
    203 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by s.tyler58 View Post
    Short answer is NOPE.
    To check the side stand, put the bike on the center stand, then lower the side stand and see if there is up and down play in it. You will not feel any movement with the weight of the bike on it.
    Doing the bolt mod is cheap and easy insurance.
  9. Thanks s.tyler58 gave thanks for this post
Similar Threads
  1. side stand (kick stand)
    By WESTDYKE in forum Second Generation Venture Tech Talk ('99 - '13)
    Last Post: 01-25-2013, 11:33 PM
  2. Center stand and side stand mod.
    By FuzzyRSTD in forum Royal Star and Royal Star Tour Deluxe Tech Talk
    Last Post: 07-06-2011, 12:17 AM
  3. Side Stand
    By johnny canuck in forum Second Generation Venture Tech Talk ('99 - '13)
    Last Post: 04-04-2009, 11:08 AM
  4. Side Stand
    By Condor in forum First Generation Venture Tech Talk ('83 - '93)
    Last Post: 07-16-2008, 06:01 PM
  5. Side Stand?
    By DevilDog in forum First Generation Venture Tech Talk ('83 - '93)
    Last Post: 05-27-2008, 03:24 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
