Atoolnut Posted June 18, 2015 #1 Posted June 18, 2015 Looking for frame dimensions for one of these.also size of box..length of tongue..thank you
eusa1 Posted June 18, 2015 #2 Posted June 18, 2015 @ditchdoctor has one of these for sale if you get south of the border into Wisconsin??
Eck Posted June 18, 2015 #3 Posted June 18, 2015 Not sure if this is all what you are looking for. If not, you could just go to your local Harbor freight with a tape measure. Name 600 lb. Capacity 78 in. Tag-Along Trailer SKU 66771 Brand Haul-Master Application 600 lbs. auto; 200 lbs. motorcycle Assembly required (y/n) Yes Certification DOT compliant Material ABS/Steel Maximum GVR (lb.) 770 lb. Quantity 1 Trailer fitting 1-7/8 in. Product Height 38 in. Product Length 6-1/2 ft. Product Weight 144 lbs. Product Width 44-1/2 in. Shipping Weight 147.80 lb. Size(s) 78 in. Tire size (in.) 4.8 x 8 in. Accessories Included coupler, safety chain, wiring harness, trailer light kit, and license plate holder Or: For technical questions, please call 1-888-866-5797.
Atoolnut Posted June 18, 2015 Author #4 Posted June 18, 2015 thanks saw that on harbor frieght website...im in canada we dont have HF yet..need the actual frame size not the overall size ..thanks
Wrench Posted June 19, 2015 #6 Posted June 19, 2015 I just measured the framework of my HF Tagalong, it is 33" long x 29" wide, the framework is 2" x 2" square tube. the tongue measures 49" long, and is 2 1/2" wide x 2" high(thick), and it attaches underneath to a 2" x 2" crossmember, and it has a 1 7/8" ball coupler. I didn't measure the dimensions of the clamshell but will if you need them. It overhangs the framework by about 1 1/2" all around.
Atoolnut Posted June 20, 2015 Author #7 Posted June 20, 2015 thanks for this info..have the hf small trailer kit and a clamshell and i want to make this as narrow as possible..the tagalong looks narrower than the regular hf trailer..thinking about inset the wheels a bit to make trailer as wide as the bags..anybody cut one of those clamshells and reglued or fiberglassed the tub?.. thanks to all who replied
