Quickly glancing through the owners manual, I see no reference to oil filter or fuel filter yamaha parts numbers. Does anyone know these? Perhaps there are aftermarket filters that would work..ie NAPA or such? Thanks for the help.
CH6002 can be got at Canadian Tire. Check this link and cross referance so see if there is something else.
http://www.venturerider.org/forum/showthread.php?t=523
Also the fuel filter can still be got at Yammy but an aftermarket one will fit....let me see if I can find that link.
Found it...read this and see if it helps.
http://venturerider.org/forum/showthread.php?t=12240&highlight=fuel+filter
Fuel filter - I'd just use a 1/4" filter from Autozone.
Oil filter:
STP SMO 02
Fram CH6002
WIX 24933
Purolator ML16802
Emgo 10-28500
  • 2 months later...
I just replace the fuel filter on my 89 VR and I attached a couple of pics. The top filter is the one already in the bike. I suspect it is NOT the Yamaha OEM and I believe it is NAPA 3011. Our local NAPA did not have the 3011 in stock, but he did have the one shown installed in the bracket. It is #3007 and I think it is 5/16 inch. Since my hoses were already over that size in the original it fit perfect. It is not as clear, but you can still see the fuel level in the filter. One odd thing, I see air bubbles coming into the fuel filter from the tank side. It is not a lot, just one bubble every now and then. The fuel level in the filter does not change or go down even under higher revs. Has anyone else experienced this or have comments. Thanks.
