dacheedah Posted October 15, 2011 Posted October 15, 2011 Ok I was cleaning my garage, a work in progress, when I came across my dremil tool. A light bulb went off as I purchased aftermarket saddlebag rails and they are smaller diameter. I did try some grommets but didn't like the look ( can you say afterthought) and they didn't work well. I decided to mark the location of the rails and with a sanding wheel remove some plastic to allow for mounting in the original position. I used the insides as a template for the radius as a starting point and a small sanding wheel to ease away the plastic. Once one sided was done and fit I placed them together to position the other half and repeated the process.
