edtheguy Posted August 24, 2012 Share #1 Posted August 24, 2012 Anybody know where I can get an antenna and bracket? Mine broke las t week while doing a 400 mile run thru Michigan. Thanks Link to comment Share on other sites More sharing options...
bongobobny Posted August 24, 2012 Share #2 Posted August 24, 2012 Ebay?? Partshark??? Some nice member here?? You may want to consider upgrading your CB to a firestick and fabricate a new mount. Just where did the mount break? Did the bolts come unscrewed? Did it rip the cable when it fell off??? Link to comment Share on other sites More sharing options...
GolfVenture Posted August 24, 2012 Share #3 Posted August 24, 2012 I have part of one. Get back to you today. Link to comment Share on other sites More sharing options...
edtheguy Posted August 25, 2012 Author Share #4 Posted August 25, 2012 Actually I got lucky. There is another mounting bracket on the opposite side and I remounted it there, had enough cable to pull to other side and all good. Only need the upper half of antenna, guess it came apart when it came down. As far as the break goes, it was right at the weld to the chrome frame that supports the the rear luggage box( if that's what it's called) Thanks for the help though. Link to comment Share on other sites More sharing options...
bongobobny Posted August 25, 2012 Share #5 Posted August 25, 2012 OK so what you really need is the trunk mounting bracket! I had one a month ago but gave it away. Glad you were able to fix it! Link to comment Share on other sites More sharing options...
