User Tag List
Thanks Thanks:  0
Likes Likes:  0
Results 1 to 6 of 6
Thread: MK2 Front end on MK1
  1. #1
    Join Date
    Apr 2015
    Montreal
    Canada
    QC
    Post Thanks / Like
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Default MK2 Front end on MK1
    Hey guyz!
    I would like to take the front end from my 1988 and swap it onto my 1985. Also, inversly, I want to installe the front ends from my 1985 ont my 1988.
    That is because the 1985 is my keeper and the 1988 will get resold.
    Do the tubes from one slide right into the triples?
    Anything to consider?
  2. #2
    Join Date
    Aug 2006
    Johnson City TN
    TN
    Post Thanks / Like
    Mentioned
    21 Post(s)
    Tagged
    0 Thread(s)
    Default Re: MK2 Front end on MK1
    Are you also going to convert the electric anti dive set up from the MKII to the MKI?
    If you have not done it already, I suggest highly that you install progressive springs in your keeper.
    Randy
    Ride as though you are invisible, not invincible.
  3. #3
    Join Date
    Aug 2006
    Brantford
    Canada
    ON
    Post Thanks / Like
    Mentioned
    120 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Venturous Randy View Post
    Randy
    Right on Randy!!
    Do it now, before you forget again.
    Register today
    Rally @ T h e S h o r e s
    July 16-19th 2020
  4. #4
    Join Date
    Aug 2006
    Johnson City TN
    TN
    Post Thanks / Like
    Mentioned
    21 Post(s)
    Tagged
    0 Thread(s)
    When I converted my 83 to MKII forks with R6 rotors, I considered making a mod to powering the anti dives. Given the amount of power they take and the inadequacies of the MKI charging system, I bought a couple of small 12 volt timer relays. The way they work is when you close a circuit, like putting on the brakes, the relay will supply power to the brake electric solenoids. With the timer function, the power would only last as long as the timer is set and I think these are adjustable from one to ten seconds. This means that for a hard stop, the solenoids would get powered for ten seconds, then power would go off. If you put on the brakes as to coming to a stop at a red light, after ten seconds, if that was what you had the timer set, the timer would break the power circuit and no more load. You could sit at the light as long as needed with no load unless you let off the brakes and then put them back on again and then the timer power would restart.
    In the vast majority of our riding and using the brakes, the anti dives are not needed. It is that panic or hard stop where they can be beneficial.
    But, when all was said and done, I never did power the electric anti dives as I quit riding the bike. I do remember that with the progressive springs, when I did make a hard stop, I never encountered the forks bottoming out.
    Randy
  5. #5
    Join Date
    Apr 2015
    Montreal
    Canada
    QC
    Post Thanks / Like
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Randy
    Propbably not. I had permanently enabled them(the hydraulic version) on a previous Venture I had.
  6. #6
    Join Date
    Aug 2006
    Carmichael CA
    CA
    Post Thanks / Like
    Mentioned
    100 Post(s)
    Tagged
    0 Thread(s)
    Besides the AD issue, there,s the difference in calipers and mounting issues...
Similar Threads
  1. front end wobble
    By gez in forum Royal Star Venture Tech Talk ('99 - '13)
    Last Post: 07-12-2013, 11:34 AM
  2. Front end
    By usedcyclesales in forum Royal Star Venture Tech Talk ('99 - '13)
    Last Post: 02-19-2012, 12:27 AM
  3. Replies: 18
    Last Post: 01-19-2012, 06:49 PM
  4. New front rim try # 2
    By dingy in forum Venture and Venture Royale Tech Talk ('83 - '93)
    Last Post: 10-02-2011, 08:34 PM
  5. Those front two plugs!!!
    By Danimal in forum Royal Star Venture Tech Talk ('99 - '13)
    Last Post: 02-10-2009, 06:17 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
