need little help from the group
I'm now getting to work on my 86 royale. i have a problem when i put the bike while running in gear there is a noise , a chatter from the drive shaft area, and no forward movement. I have taken the drive shaft off and i dont seam to any probem with it. Please help me with my next step
You need to inspect the pinion gear. Take the hub off and open it, it is not difficult to do, then you need to man handle the pinion see if its connected or sheared..
You Check the shaft Ujoint as Carl mentioned, also with the shaft removed put the bike in gear and listen for noise,,, likely it will sound normal, pointing again to the hub.
Patch
Edited by Patch
