Guest bikerrrbob Posted August 31, 2008 Share #1 Posted August 31, 2008 Hello, thanks for welcoming me to this forum, I have a 2005 Royal Star with custom exhaust installed at the dealer, he also rejetted the carbs, thing is, sinse then It's been getting lousy fuel mileage, less than 200 km's on a tank at 110 km's/hr. I think he went too big with the jets but I don't know what the factory settings are, main, pilot, ect., also thinking of installing a K&N air breather to help out. Any help on this matter would be apreciated. Bikerrrbob Link to comment Share on other sites More sharing options...
pegscraper Posted August 31, 2008 Share #2 Posted August 31, 2008 Welcome aboard. Were just the mufflers changed, or were the head pipes also changed for bigger ones? A muffler only swap doesn't generally require rejetting. Usually just backing out the pilot mixture screws a bit is enough. Stock jet sizes: pilots are #15, and mains are #122.5 for cylinders 1 and 2, #117.5 for cylinder 3, and #120 for cylinder 4. The staggered main jetting is a little strange. No one has a real good explanation for it, especially being a water cooled engine. But that's what they did. K&N air filters don't require rejetting either, which tells me that they do absolutely nothing for increasing the airflow or performance on this bike, or else they would require rejetting. Link to comment Share on other sites More sharing options...
Guest bikerrrbob Posted August 31, 2008 Share #3 Posted August 31, 2008 Thats great, thank you, now I have a starting point to work from. Bikerrrbob Link to comment Share on other sites More sharing options...
bikenut Posted September 1, 2008 Share #4 Posted September 1, 2008 In MY 2006 Venture I run a 17 pilot in all carbs and up one jets size more in each carb. I get 38 mpg pulling a trailer running about 65mph. And it is loaded most of the time. I have the dyna 300 setting 3, Opened up air boxes, RK Pipes with just baffle left in,Jason Mod, Shimed neddles 10 thousands, Torque Masters under the carbs, Run Amsoil 20/50 and syn rear end lube also. Bikenut:cool10: Link to comment Share on other sites More sharing options...
speakerfritz Posted June 5, 2014 Share #5 Posted June 5, 2014 do all rejet kits require drilling? I have a 2013 venture I want to rejet 1 step up in jet size. Link to comment Share on other sites More sharing options...
lonebiker Posted May 22, 2019 Share #6 Posted May 22, 2019 Has anyone tried the same size main jet in all carbs? Like say 130 in all 4 carbs Link to comment Share on other sites More sharing options...
