thecount Posted August 27, 2008 Author Posted August 27, 2008 The Mic on/off switch with the lower cord will work on the head set it is attached to. You would have to buy a switch for each lower cord. Since most of the wind noise is coming from the rear helmet Mic you could probably get away with just buying a switch for the rear Mic. Earlier, I was talking about a product called "Mic-Mutes" that is plugged in-line with your intercom system out of sight inside the front fairing and under the passenger seat that are operated using the bikes PIT buttons. I've been using it for 2 years now and it completely stops the wind and engine noise when your not talking through the Mic's. The kit comes with instructions that are easy to follow. http://mic-mutes.com/ Thanks alot for the web link. Will check that out. Sounds to be a great solution.
