scott_sinky Posted August 10, 2008 Share #1 Posted August 10, 2008 Hi All, I just finished replacing my TID Unit, which went better than I expected. Anyway, now the emergency flashers and turn signals don't work. The front signal lights are on but don't "blink". The fuses all look ok. I did accidentally arc across the device that is hanging off the left side of the battery box. (I don't know what it is called) Everything else seems to be working fine. Any ideas? Thanks for your help. Scott Link to comment Share on other sites More sharing options...
shighley Posted August 10, 2008 Share #2 Posted August 10, 2008 Hey Scott; Check to make sure the 4 way flasher switch is all the way "Off". Cycle it a few times and try the turn signals again. Good luck and ride safe, Steve Link to comment Share on other sites More sharing options...
Dano Posted August 10, 2008 Share #3 Posted August 10, 2008 The unit hanging off the left side of the battery is your starter relay....... Link to comment Share on other sites More sharing options...
Condor Posted August 10, 2008 Share #4 Posted August 10, 2008 OK, gotta ask. Which one's the TID??? Link to comment Share on other sites More sharing options...
GeorgeS Posted August 10, 2008 Share #5 Posted August 10, 2008 We will answer any and all Questions: However you must use the correct Nomenclature, for all highly technical questions !! Link to comment Share on other sites More sharing options...
Condor Posted August 10, 2008 Share #6 Posted August 10, 2008 We will answer any and all Questions: However you must use the correct Nomenclature, for all highly technical questions !! Like thing-a-ma-jigs... Doo-hickeys.. chinga-deros, gizmos..... :-) Link to comment Share on other sites More sharing options...
scott_sinky Posted August 11, 2008 Author Share #7 Posted August 11, 2008 I'm doin' the best I can on part descriptions. On another note, thanks to the input I received as well as searching older posts, I solved my flasher problem. The wires were unplugged. DUH! Scott Link to comment Share on other sites More sharing options...
