Grandpagak Posted April 22, 2007 Share #1 Posted April 22, 2007 help!!! i cant seem to find anything on how to bleed the clutch.. and i cant find a bleeder.. i have 2 bikes that need this done on them.. :bang head: :bang head: Link to comment Share on other sites More sharing options...
WilCruise Posted April 22, 2007 Share #2 Posted April 22, 2007 It's a standard bleed process. The valve is under a little rubber cover on the left side cover of the engine. It can be tricky though. I have found using speed bleeders (which you can get 2 for $15) makes it a lot simpler. Link to comment Share on other sites More sharing options...
hipshot Posted April 22, 2007 Share #3 Posted April 22, 2007 gary, just below the left, rear ,valve box(#1cyl), there is a small rubber square that must be pulled up to expose the bleeder. i thought i never would find it, and without some help from these guys,around here, i probably would still be a huntin' it! just jt Link to comment Share on other sites More sharing options...
Yammer Dan Posted April 23, 2007 Share #4 Posted April 23, 2007 Pull the clutch lever in against the handle bars tie it there and leave overnight. Loosen top of cylinder cover, add fluid if needed the next morning and clutch is bled. Link to comment Share on other sites More sharing options...
Grandpagak Posted April 23, 2007 Author Share #5 Posted April 23, 2007 THANX GUYS.. I MAY HAVE NEVER FOUND THAT BLEEDER.. Link to comment Share on other sites More sharing options...
