GaStar Posted August 15, 2023 Share #1 Posted August 15, 2023 (edited) I just made a 1286 mile round trip from Omaha to Sturgis and back. We ran 2 up with gear, but no more than would fit in the bags. We only were gone for 3 days. My overall mileage was 31.967. I did calculate mileage between fuel stops. When we were running on the scenic roads at 35-45 mph, I seemed to get around 36 mpg. When we were running interstate at 70-75 I was getting 27-28. Does this seem normal to you guys? I've been slowly leaning out the carbs since I bought it. It was so rich that I could smell raw fuel while I was riding and it was really bad at a stop sign. All cylinders are firing. Carbs are synced. Tire pressure has been checked. I'm thinking of doing a Dyno tune. I don't have a gas analyzer. Edited August 15, 2023 by GaStar forgot pic Link to comment Share on other sites More sharing options...
djh3 Posted August 17, 2023 Share #2 Posted August 17, 2023 Been a long time, but seems about right to what I would get. I may have got low 30s on the high speed stuff, but I am a cruise control guy. So of that would probably depend on how much weight you had packed up too. Link to comment Share on other sites More sharing options...
Du-Rron Posted August 17, 2023 Share #3 Posted August 17, 2023 On 8/15/2023 at 3:09 PM, GaStar said: I just made a 1286 mile round trip from Omaha to Sturgis and back. We ran 2 up with gear, but no more than would fit in the bags. We only were gone for 3 days. My overall mileage was 31.967. I did calculate mileage between fuel stops. When we were running on the scenic roads at 35-45 mph, I seemed to get around 36 mpg. When we were running interstate at 70-75 I was getting 27-28. Does this seem normal to you guys? I've been slowly leaning out the carbs since I bought it. It was so rich that I could smell raw fuel while I was riding and it was really bad at a stop sign. All cylinders are firing. Carbs are synced. Tire pressure has been checked. On 8/15/2023 at 3:09 PM, GaStar said: Here is my take on Fuel economy Fuel Economy discussion along with timing advance chart. Link to comment Share on other sites More sharing options...
GaStar Posted August 17, 2023 Author Share #4 Posted August 17, 2023 15 hours ago, djh3 said: Been a long time, but seems about right to what I would get. I may have got low 30s on the high speed stuff, but I am a cruise control guy. So of that would probably depend on how much weight you had packed up too. Honestly we didn't have much packed. A few tools, a days worth of clothes and 1 half shell helmet. Link to comment Share on other sites More sharing options...
GaStar Posted August 17, 2023 Author Share #5 Posted August 17, 2023 3 hours ago, Du-Rron said: Here is my take on Fuel economy Fuel Economy discussion along with timing advance chart. Very informative. Thank you! So it sounds like I'm in line to what I should expect. Perfect. I can still tweek some here and there, maybe do the vacuum line mod, jasons mod, and see what that does. I can always go back stock. They said the K&N filters were just serviced and oiled before I got the bike. I should check them out because they also said they did a fresh oil change as well and it was overfilled above the site glass! Link to comment Share on other sites More sharing options...
