MihaO Posted May 16, 2023 Share #1 Posted May 16, 2023 Hello, I haven't found a topik to my problem yet, so I'll just start a new one. I own a Royal star venture imported to Slovenia from US. This year I had carbs renewed, changed all filters, changed fuel pump, spark plugs basically all I could think of. The problem remains, when I switch to 4th gear bike starts to stall, like there isn't enough fuel. I change from 3rd to 4th at about 50-55mph and she just loses power. Tried reving up in 3rd up to 70mph and it starts the same after few seconds in 3rd. If I accelerate in 4th from about 35mph, I can only get to 50-55mph and then it has only enough power to keep the speed. Like I said , everything possible was changed and no difference. Mechanic said it could be pickup sensor, but there is no backfire. If anyone has any idea I would much appreciate your help. Thank you and ride safe. Miha O. Link to comment Share on other sites More sharing options...
Marcarl Posted May 16, 2023 Share #2 Posted May 16, 2023 Check your air intakes to make sure they are open and clean right to the carbs, also use oem filters. Maybe try taking a run without airfilters and see if that makes any difference. Maybe the computer? Link to comment Share on other sites More sharing options...
