MihaO Posted May 16, 2023 Posted May 16, 2023 Hello, I haven't found a topik to my problem yet, so I'll just start a new one. I own a Royal star venture imported to Slovenia from US. This year I had carbs renewed, changed all filters, changed fuel pump, spark plugs basically all I could think of. The problem remains, when I switch to 4th gear bike starts to stall, like there isn't enough fuel. I change from 3rd to 4th at about 50-55mph and she just loses power. Tried reving up in 3rd up to 70mph and it starts the same after few seconds in 3rd. If I accelerate in 4th from about 35mph, I can only get to 50-55mph and then it has only enough power to keep the speed. Like I said , everything possible was changed and no difference. Mechanic said it could be pickup sensor, but there is no backfire. If anyone has any idea I would much appreciate your help. Thank you and ride safe. Miha O.
Marcarl Posted May 16, 2023 Posted May 16, 2023 Check your air intakes to make sure they are open and clean right to the carbs, also use oem filters. Maybe try taking a run without airfilters and see if that makes any difference. Maybe the computer?
