MongoE9 Posted April 27, 2023 Posted April 27, 2023 While riding up a hill in 5th gear doing approx. 70 mph I heard what sounded like an engine backfire pop then lost all transmission power. Engine whined and I limped to the shoulder. I had no gears to hold from rolling back downhill. Clutch lever seems to operate properly, and the shift lever seems to operate properly as well. I trailered it to my destination and hours later had just enough trans power to limp into another trailer. Now at home, after several days I tried it again and with the clutch pulled in and trying to start in gear the bike tries to roll forward. When I shift from neutral to 1st I heard a grinding noise and then back to nothing again. I am nowhere near as mechanically talented as the majority of you are. Any help will be greatly appreciated. Thank you!
Marcarl Posted April 28, 2023 Posted April 28, 2023 Sounds like it might be the u-joint going to the drive shaft,, maybe.
