ZOEYDOG Posted June 1, 2019 Posted June 1, 2019 Any one drill out the exhaust if so can you give me instructions how and did it affect performance
mbrang00 Posted June 3, 2019 Posted June 3, 2019 Any one drill out the exhaust if so can you give me instructions how and did it affect performance Drilled mine with (4) 1/2" holes in each side. It did not do anything to performance, but it did improve the sound of the exhaust making it a little deeper sounding and a tad bit louder. If you choose to drill it out, do so at your own risk...but all it takes is a drill, 12" drill extension, and a drill bit or a hole saw (depending on how big you want to drill out). There are a few folks that have drilled out the entire baffle with a 1-1/2" hole saw and have reported positive results with sound...but not performance. Basically you drill out the baffle plate that you see inside the muffler. stick a flashlight in the end of the muffler and you will see the plate at the end...keep in mind, the muffler on the left has a center hole from the factory and the one on the right does not have any on the plate.
