Cougar Posted May 25, 2018 Author Share #26 Posted May 25, 2018 cut it out just now, thanks, and my forks have a drain plug in them at the bottom of each fork... what size did you guys cut the plastic tube for the progressive springs ? and did you use to same amount of fork oil ? Link to comment Share on other sites More sharing options...
Cougar Posted May 25, 2018 Author Share #27 Posted May 25, 2018 Oh my !!! Link to comment Share on other sites More sharing options...
Freebird Posted May 25, 2018 Share #28 Posted May 25, 2018 Sorry, can't help you with the Progressives. Never used them. I firmly believe the Sonics are a better choice for the RSV. Link to comment Share on other sites More sharing options...
Freebird Posted May 25, 2018 Share #29 Posted May 25, 2018 This thread doesn't directly answer your question but may give you a clue. http://www.venturerider.org/forum/showthread.php?19608-Front-Fork-Sag Link to comment Share on other sites More sharing options...
Cougar Posted May 25, 2018 Author Share #30 Posted May 25, 2018 (edited) Spacer Cut is 6.75 inches. Using 15 wiehgt BelRay fork oil. 18 oz Yeah Don, I think these should be fine since the bike is triked I had Already ordered them and got them for $52 so I hope they work for my Bottoming out , otherwise my steering is upright at all times , no leaning. Edited May 25, 2018 by Cougar Link to comment Share on other sites More sharing options...
Freebird Posted May 25, 2018 Share #31 Posted May 25, 2018 I'm sure they will be fine. Much better than stock. From what I understand, the problem is that Progressive never actually made a spring for the RSV. The one that they sell was designed for the older Royal Star and it was much lighter. So the spring rate is really not heavy enough for the RSV but probably heavier than the stock springs. Link to comment Share on other sites More sharing options...
Cougar Posted June 2, 2018 Author Share #32 Posted June 2, 2018 Well, I am DONE !! Its raining so when that lets up I am going for a ride :-) I don't think I want to ever do that again LOL , seem like it took forever. I did learn lots tho. I also had to wait on parts as well. so anyways lets hope the front end stays together ! :-) Jeff Link to comment Share on other sites More sharing options...
