Srbrown Posted May 9, 2018 Share #1 Posted May 9, 2018 Hey guys , I misted the first step in my clutch inspection. I did not pull the clutch lever in and tie it off before disassembly clutch basket, so how do I now extend the shaft rod manually to re install the clutch basket. thanks Steve Link to comment Share on other sites More sharing options...
Marcarl Posted May 9, 2018 Share #2 Posted May 9, 2018 Shouldn't have to worry about it. I think the point of pulling the handle before you start is that it wouldn't happen after you have everything apart. I never pulled mine and everything worked just fine. Link to comment Share on other sites More sharing options...
Sylvester Posted May 13, 2018 Share #3 Posted May 13, 2018 What Carl said. Link to comment Share on other sites More sharing options...
