Gary Klop Posted June 10, 2017 Share #1 Posted June 10, 2017 I have a 87 and when I went to hook my battery up this spring I hooked the neg up first---main problem ,,,which blew the main fuse. I finished hooking battery up and found my spare fuses and replaced it. When I went to plug it back in it blew again. DO I need to unhook the battery, replace the fuse and hook it back up then hook up the pos then the neg to keep it from blowing again? thanks Link to comment Share on other sites More sharing options...
djh3 Posted June 11, 2017 Share #2 Posted June 11, 2017 Shouldn't make any difference which side of battery you hook up first. I typically hook up the neg last. If it is blowing fuses as soon as connected, it has a dead short somewhere. Link to comment Share on other sites More sharing options...
Karaboo Posted June 11, 2017 Share #3 Posted June 11, 2017 You could try pulling all the fuses and put them back in one at a time. Then see if you can find the short. If you can read the circuit diagrams, you could try to find it with a meter. Patience is the hardest thing to master with electrical issues. At least for me. Link to comment Share on other sites More sharing options...
