Pappa Bear Posted April 21, 2008 Share #1 Posted April 21, 2008 On my 89 VR 2 of the carbs are wet with gas as far up as I can see without taking things apart. Looks like the front carb on left side and rear one on the right side, both look to be wet from the middle down. Leaks so that when on side stand it had a small puddle on the garage floor about the size of a coffee cup coaster. I drove it Saturday and overnight it piddled on the floor! Naughty Bike!!!! Any suggestions? Link to comment Share on other sites More sharing options...
GeorgeS Posted April 21, 2008 Share #2 Posted April 21, 2008 Sounds like the hose from the fuel pump to the top of Carbs, has a leak. Get access to the top of carbs, to work on the fuel lines, you will have to remove the Air Cleaner Box. Link to comment Share on other sites More sharing options...
