This is my next project....
I asked in another post where to put the relay and control box, and someone suggested behind the passenger seat rest.
Is that behind the cushion, or in that little panel in the plastic? Anyone know?
Always looking for ideas....
Also, how much room is below the passenger seat? Enough for a 1-1/4" square relay and a small control box?
Any ideas in figuring out how much room is under that seat? gobs of play-doh or something??? hmmm....
Has anyone drilled into the bottom of their trunk to pass wires through and install stuff there? Yes??? NO???
TIA as always!
Mike
I have two of those square relays mounted on that plastic pan in the rear area next to the frame with room to spare.
Yup, I have additional lights on my trunk. and a 5 wire to 4 wire system converter, I drilled a hole just big enough to force the wires through and sealed it up with RTV. I used a 5 wire flat trailer connector with the connectors external to the trunk so that I can unplug and remove the trunk...
There isn't much room under the passenger seat. The area I had mentioned before is behind the passenger back rest.
Thank you so much. Ok... Now I need it to stop raining!
