You looking for a two pin white connector, both halves of the connector are there, the one side is dummied off with rubber plugs. the wires are Black = Ground the power is Brown with Red stripe.
Normally you will find it on the left side down low.
I am not sure, the wiring diagram does not say where the fuse is located, but if memory serves me it is in one of the fuse boxes. It is a very low amperage circuit, maybe 5 amps.
