GolfVenture Posted July 1, 2016 Share #1 Posted July 1, 2016 From my last clutch issue, I needed to drains some clutch fluid for I filled it full and the clutch level was way too tight. It sat for about 3 weeks, and I finally got to it. Well when I open the fluid lid the fluid level was down just past 1/2. I looked at the cement floor, I found that it was leaking. It is not leaking from the reseivor. Besides checking tthe bleeding valve, what else can I check? Link to comment Share on other sites More sharing options...
Patmac6075 Posted July 1, 2016 Share #2 Posted July 1, 2016 Sounds like a leaking slave cylinder!? Only choice is to remove and either replace or rebuild. There are some articles in the tech section. Most will tell you just get a new one (I'm guessing around $80), but I rebuilt mine....it was easy, and knock on wood hasn't leaked. This is the write up I did, http://www.venturerider.org/forum/showthread.php?116337-Clutch-Hydraulic-Rebuild-Tutorial Link to comment Share on other sites More sharing options...
GolfVenture Posted July 1, 2016 Author Share #3 Posted July 1, 2016 I think I have the one off my wrecked 91 VR. I will try to swap it out. It only has less than 10k miles. Link to comment Share on other sites More sharing options...
Larry1963 Posted July 2, 2016 Share #4 Posted July 2, 2016 mine leaks too, someone in here is selling them, I think new. I haven't had the funds and time at the same time if the other guy doesn't want your used one let me know Link to comment Share on other sites More sharing options...
