Lug Nut Posted June 22, 2016 Posted June 22, 2016 I a tried to use washers to bring whole ligjt bar downward-angled a bit. Didn't seem to work. My passing lights are angled up to the trees! What is the best way to bring them down?
RedRider Posted June 22, 2016 Posted June 22, 2016 Take the light bulb out and loosen the clamping nut in the housing. You can then adjust the targeting. Tighten back down and replace the bulb. RR
Lug Nut Posted June 22, 2016 Author Posted June 22, 2016 Thanks! I was trying unsuccessfully to do this externally!
aharbi Posted June 22, 2016 Posted June 22, 2016 The bolts are hollow, DON'T OVER TORQUE! Almost impossible to find a replacement. Just sayin
Yammer Dan Posted June 23, 2016 Posted June 23, 2016 Wipe those bulbs off with a good soft cloth before you turn them on or they will blow!!!
Lug Nut Posted June 23, 2016 Author Posted June 23, 2016 Got them about as good as I can....what a pain in the ass to adjust
