Old Buck Posted June 19, 2016 Posted June 19, 2016 Just purchased an 84 Venture with 30k on it. In going through it I found that the saddle bags don't seal tight and leak. There is a little adjustment in the catches but not enough to make a difference. It appears that finding new seals might prove difficult. Has anyone resealed their saddle bags before or possibly modified the latches to allow more adjustment for a tighter seal? Thanks Old Buck
Venture n Dixie Posted June 19, 2016 Posted June 19, 2016 (edited) http://www.venturerider.org/forum/showthread.php?91963-water-leaks&highlight=Leak That thread is for the trunk. Haven't found the thread about using window screen spline on the bags. Seems like there is large and small spline and I think the large is the correct size. Will keep searching for that thread. I'm curious also. Edited June 19, 2016 by Venture n Dixie
Old Buck Posted June 19, 2016 Author Posted June 19, 2016 Now that sounds like a plan! Been racking my brain trying to figure out something that might work. Thanks Venture n Dixie for pointing me in the right direction. Old Buck
Yammer Dan Posted June 20, 2016 Posted June 20, 2016 You are on the right track. Been a while since I done that but got mine at Lowe's. If I remember right you can look at it and guess right size when you go to store.
Prairiehammer Posted June 21, 2016 Posted June 21, 2016 The Yamaha part number for the saddlebag and trunk gasket/seal is 54K-2847F-00-00. There is a seller on eBay offering the seal. http://www.ebay.com/itm/TRAVEL-TRUNK-LID-SADDLEBAG-SEAL-54K-2847F-00-XVZ12-XVZ13-1983-1993-/331204614483?pt=Motorcycles_Parts_Accessories&hash=item4d1d555953&vxp=mtr&rmvSB=true
