Hey all, 2007 Midnight Venture, 29k, clutch is slipping, I did an upgrade with PCW on my 01 years ago, and it was fine, is that still the best option?
It's the easiest/cheapest. The other alternative is to go with the Barnett upgrade but it is more expensive to do, but it may be better than the PCW...
For a reasonably stock bike and reasonable loads the SkyDoc Kit, PCW or EBC upgraded diaphragm spring is the most likely recommendation. If you tow a trailer and ride VERY aggressively the Barnett plate upgrade is slightly better as you can swap the coil springs.
